i got my first quad and there is two wires just sitting ther not conected is that were the cdi goes none of electricity works will that help
Welcome to QUADCRAZY! What year, make, and model is your atv?
Acronym for "capacitive discharge Ignition" device sometimes controlled by a computer . It is designed to help the spark plug fire at a rate consistent with the rpms of the engine.
    • By Frank Angerano
    • By anthonyd256
      I have a 99 Yamaha bear tracker and I have converted the front brakes from drum to disc fairly easy but I cant figure out how to convert the rear with out hacking apart the rear arm. tried to use parts from a wolverine since the rear arms look similar but the caliper mount didn't line up on the bear tracker axle. Can anyone give me any clues or has anyone successfully converted the bear tracker rear brakes. I would even purchase a conversion kit if there is one. Any help on this would be greatly appreciated.
