I wish
By sandman001
By Wanheda
Necesito ayuda para saber como puedo ajustar yo mismo el cable del acelerador de mi atv, esta nueva, recientemente lo lleve a su primer servicio y lo "arreglaron" pero ayer volvió a fallar, lo que pasa es que de la nada como que se afloja y por más que presione la palanca de aceleración nada más no avanza, he intentado repararlo y en ocasiones queda bien pero después le pasa lo mismo, y quisiera saber como funciona para poder repararlo ya que aun falta bastante para su siguiente servicio además de que para llevarla al servicio debo rentar una camioneta para llevarla ya que esta algo lejos el centro de servicio, así que por favor si me pueden ayudar, se los agradecería mucho
By RRP
My new 2023 Polaris Sportsman 850 is in the shop for a pinched Wiring Harness from the factory...
I did one ride on it (100kms), then to the shop for a month, waiting for them to replace it with a new one.
By SalvatoreHernwood
I just picked up a new scrambler 850 and I’m looking to see if anyone has information on known issues with the 18-23 models. Just seeing if there is anything I can or should get ahead of or prepare for. It will be used for trail riding at medium to fast paced speeds. Lots of rocks where I ride so things tend to take a bit of a beating. Thanks for any insight!
By Mike Johnson
Hello Guys, I'm new to the site, but have been reading about all the issues that I to have had with my quad. I have rebuilt the carb a few times, once when I got it a few years ago and again a few weeks ago. Same problem, it cranks fine and idles well but when I take off it stumbles. After looking at the site I saw all the posts about the rectifier/regulator so I grabbed one off eBay which came today. Once I found out where it went I saw that the original one wasn't there so I have no reference however I mounted it and began to connect it but one the plugs doesn't fit. The red/black plug connected fine but the yellow wire plug doesn't, and I don't see any other plugs available. Apparently the guy I bought it from had removed the original regulator and it wasn't with the ATV so I have no idea what it looks like. I will also say that I was surprised that it didn't have a rectifier on it but cranked and ran fine till the stumble. My question is, do those yellow wires have to be hooked up ? And my apologies for the rambling, I'm doing this on a phone and can't see the screen. Hahaha
