Ok got the atv running like a champ just need a battery......but wait i look on the floor and gas is all over the floor......the gas was leaking from the intake..and out of the hose leading from the float bowl....plz help...oh yea ima put a video up......yea sooo:aargh:
its a chinese quad.....ummmm...on the plastics it says 200st........all chinese engines r the same.... but the sizez of frame r differnt and diffrent ccs
I changed the title to try and be as descriptive as possible with the info given.
I agree 100% with Bot, that sounds like a stuck float to me too. I would take the carb apart and check the float adjutment and for any debris that may be causing the float needle to hang up.
  • 7 months later...
ck.for stuck needle valve,needle not seeting proper ,hole in float,bleed screw loose in bottom of carb,if no one has messed with carb,do not try to reset float,it was set at factory to close the needle valve as the gas feels up the carb bowl,they dont unset them selves,
    • By RadRob
