I have a sportsman 90 for my kids. There was a slight slip in the gear when i purchased it(when they ride together or there is more tension on it). I'm assuming this is the drive shaft and I've been debating on trying to fix this myself. Just curious if anyone has had this problem and how complicated it is to fix?
Not exactly sure what you are saying there, could you elaborate a bit please? From what I can understand it sounds like maybe a belt issue, but if you could give a little more info, it would help us help you.
hello dirt demon.
The problem i'm having with the polaris 90 sportsman is that when starting from a stop or climbing a hill the chain sproket from the engine doesn't turn and there is a loud clank. I'm thinking that this would be a drive shaft issue. I've never had one torn apart before and don't think there are any belts? I could be wrong. I'm thinking that the drive shaft has been worn to cause the slipping?
There are belts and clutches, either one could likely be the culprit. There is a cover in the side of the motor with a guard on it, the guard is held on by two bolts. You should be able to see the bottom portion of the belt after you take off the guard. After take off the guard, then the cover behind it, you will see the drive belt assembly and the clutch assembly. I would check there first before looking into the drive box. I would highly recommend buying a repair manual, it will probably have all the info you need to figure out your problem, and it will definately have info needed to properly disassemble and reassemble the machine.
      Topics covered include:
      AWD and differential repair
      Brake system service
      Popular related searches:
      Sportsman 570 wiring diagram
      Sportsman 1000 wiring diagram
      View File 2020-2026 Polaris Sportsman XP 1000 S service manual
      Download the 2020-2026 Polaris Sportsman XP 1000 S service manual PDF for complete factory repair, maintenance, troubleshooting, and diagnostic procedures. This comprehensive Polaris Sportsman XP 1000 S repair manual covers all major systems including engine service, EFI fuel injection, clutch and transmission repair, AWD drivetrain systems, suspension, steering, brakes, electrical troubleshooting, wiring diagrams, torque specifications, and factory maintenance schedules.
      Designed for ATV owners, mechanics, mud riders, trail riders, and DIY enthusiasts, this factory-style service manual provides detailed step-by-step instructions and diagrams for maintaining, repairing, and rebuilding the Polaris Sportsman XP 1000 S high-performance utility sport ATV.
      Polaris Sportsman XP 1000 S engine repair
      AWD and differential service
      Suspension and steering repair
      Brake system maintenance
      Oil change procedures and maintenance schedules
      2020 Polaris Sportsman XP 1000 S service manual PDF
      Sportsman XP 1000 S wiring diagram
      Sportsman XP 1000 S maintenance schedule
      This Polaris factory repair manual is ideal for riders looking to maintain, troubleshoot, repair, or upgrade their Sportsman XP 1000 S for trail riding, mud riding, hunting, utility work, and extreme off-road performance.
      View File 2025-2026 Sportsman 6x6 570 service manual
      Fix your ATV with the 2025-2026 Sportsman 6x6 570 service manual. Features factory torque specs, troubleshooting steps, and maintenance charts. 2025-2026 Polaris Sportsman 6x6 570 Factory service manual. Complete repair, maintenance, and wiring guide for your 6x6 ATV. Download your copy today!
