I just bought this bike Monday off the showroom floor. It was a left over from last year. I only have 20 min of ride time on it. The bike shifts into first and through the higher gears w/out any trouble, but when I down shift the shifter will stay down.... It pops right back up if I tap the side of it with my boot. Does anyone know what's going on here? I was wondering if that oil seal that the shaft goes through may be binding it up, I wouldn't think that this brand new bike would have a bent shaft already. I called the dealership and thy said they couldn't get it in till mid august.
You go in there and start raising hell, They sold you a bike with problems and are going to make you wait to get it fixed. I would be sitting there with my bike and talking sh** about their shop to everyone
I saw at their place until they took care of it.
Like bot said, start raising hell. The last thing I would do is try and fix it myself. You bought a brand new quad, there is no reason you should be working on it. If they won't look at it now, then I woud go to the salesman and tell him you want to return it. I would not leave that dealership without getting what you want.
    • By jeffrocdx
    • By jen
      Cannot find out why 12 vdc  4 (4) commutator starter motor has no power. It will run full speed without load. But with any load will not turn. Repaired broken brush holder and insulated an internal wire to magnet that was bare and rubbing. cleaned commutator segments. Ohm readings while slowly rotating commutator was 1 ohm.   When attempting to run  with load it will not turn and Bat vdc only pulls down to12vdc. Cannot find an internal wiring schematic.  I can buy a rebuild kit ~$35 but WTH?
    • By Frank Angerano
