By Toni82
I am looking Servce manual for my BRP, can any body send me it on my e-mail? Please.... I think that it's will be a long hard wway to do this ( But i want to do this by myself.
Please send on my e-mail: [email protected].
By dlgg7
I've had this for probably 15 years. It ran great till 4-5 years ago, mainly riding the grandkids around our fields, till it wouldn't start. It sat for a couple of years till I bought a new battery, but couldn't get it to even hit, so rebuilt the carb, put on a new fuel pump, but no go, so it's sat. Several days ago, charged battery, cranked over and it started??? OK, idles good, but won't rev up, so emptied gas tank, flushed out and filled w/good 93 octane, pulled pump line from carb and have good full line of fuel cranking over. New spark plug, good spark, old one black BAD! Oil change, adjusted valves, no difference. Pulled carb and took apart and cleaned, didn't find any clogs or crusted up inside. Now I've had the carb back off probably 6 times checking, double checking anything I can think of. No gas blowing back in air box. It idles good, can increase throttle up some then starts popping and dropping rpms off and if I don't let off the throttle, it'll die. I've read for 3 days now MECHs and RANDY walking several thru tracing the same problem, tried MOST of the direction given. ??? -
By 86096
I have a 1985 Suzuki lt230ge with electric start. It has a keyed ignition. The key, once inserted will move to two positions. There is a button on the left handlebar to engage the starter... so what do the two key positions do. Anyone know???? I am looking forward to getting to enjoy this machine but I can't find a lot of info online about such a classic ATV. Thanks in advance for any advice!!
By Admin
View File 2006-2019 Bombardier BRP DS250 Shop Manual
Submitter Admin Submitted 09/25/2023 Category Can-Am BRP ATV
By Jd101506
Hi all-
I’ve got a LT300e that I’m working on. The last two days I noticed as I’ve been testing it, it won’t turn off with the key. The kill switch still works to turn it off, as does everything else (lights, neutral light, reverse, starter, etc). So I guess I’m taking votes on what to do here… Ignition the issue? Wiring grounding issue somewhere?
Not sure where to start so any help would be appreciated!
