I will leave this thread open for discussion, but by doing this, QUADCRAZY does not sanction illegally obtaining any manufacturer software. Any postings on obtaining it will be removed by our moderating team. You are welcome to continue a discussion about the software and it's uses only. Thank you for your cooperation.
  • 3 months later...
    • By smallmotor2002
      Hello everyone.
      I'm working on a 2014 Yamaha 700 Grizzly and having no luck accessing the diagnostic mode on the display. I have tried with the fuel pump connector plugged and unplugged, and select and reset buttons depressed simultaneously for up to 30 seconds with no luck.
      I could sure use some assistance if anyone has any tips on this
    • By Mark Gibeault
      Does the onboard system provide everything needed to atleast point out any electrical component malfunction and is there ang benefit of using an obdll diagnostic tool with an adapter for this machines diagnostic port?
    • By flyinbrian365
      View File 2015 Textron Motors MPE 850 Diagnostic Manual.pdf
      4-Stroke Engine
      MPE 850 OFF-ROAD
      This diagnostic manual is valid for the following engine models:
      409135 I2 846 UTV NA-80
      Submitter flyinbrian365 Submitted 02/18/2019 Category Textron Off Road UTV
    • By KJINTF
      Anyone know if this software, which I use for my Yamaha EFI Outboard engines can be used on the Kodiak and or Grizzly ATV line?
      I see Yamaha uses this software / hardware interface for the Waverunner line up and the Outboard engine line up but can't determine if it is used on the ATV line.
