Would you deck your ATV out for the Holidays and enter?
33 members have voted
  1. 1. Would you deck your ATV out for the Holidays and enter?
    • YES
      16
    • NO
      17
    • By Adamb2025
    • By umax33
      i just got a 1986 honda trx 200 and the reverse and neutral lights don't work, i looked in the service manual and it says to remove two screws and the cover comes up and you can check the bulbs, the book does not show the two screws and i can't see them.Does anyone know how to get to the screws to check the bulbs. i will appreciate any help i can get...thank you
    • By adr94
      Hello,
      I was able to repair most of the little problems on my 2006 BRUIN. I still have little things to do...
      I changed the Hazard light Switch because it was not locking when pushed and now it is not working at all. When I connect it (not sure of the wiring -4 wires but a lot of connection possible on this HELLA 3916-01 switch-) the flashing lights button (on the handlebar) is acting like the Hazard light switch.
    • By Ejwill
      Headlights and taillights will not work, the dash light will not come on. Already checked fuses they are all good. Help please. 2006 Honda rancher 350 es.
    • By Beandonjb130
      I'd like to throw some reverse lights on my 1988 moto4 350 and was wondering if any one knew which wires I would tap into to to do so. I tried tapping into a couple different wires at the reverse relay but all I could get was for them to come on once the ignition key was turned on. I know there's the light for the reverse indicator light but I'm not sure if that carries the amperage to do a couple 4" led work lights.
