Artic Cat stutters and I had to keep pumping the gas to keep it running and now it has quit altogether. Have had a mechanic friend take it apart and clean and check everything and it still stuttered. Pulled the cdi box and put it on the other cat and that one ran fine with that cdi box. Any ideas as to what it could be?
    • By middlebrookgt
    • By PupATV
      Hey guys! I am new here to the forum and need some help getting my Polaris 325 Magnum 2001 Running.....So I got it for free and it has never run quite right...I put a aftermarket carb on it last year and it was running fine but it only went like 20 maybe 25mph max......But then the needle and seat sealed leaked within a yeah and it flooded it REALLY bad so I changed the oil because it was full of gas. So then I put a genuine Polaris carb on it and I have it set to all the factory specs, but it was still not running right....So I replaced the ignition coil and the spark plug and that solved one of the problems I had (It would bog down and stop running when i would go up a hill) But it still didn't have that much "Punch" to it like my Kawasaki Prairie 300 ans Suzuki Kingkuad 300.....So I replaced the CDI but it's still not running right! It's acting like it rich kinda....So it runs mostly okayish when I have the airfilter on but the top of the airbox off but as soon as I put the airbox lid on it like REALLY bogs down and wants to stall really bad. I have the carb at the factory specs and it has a pretty new fuel pump so I have no ideas whats going wrong! It still nly has a top speed of only about 30-35mph and it sounds like it's choking the whole time! Thank you for sticking to the end, and I hope you guys can help me!
      -PupATV
    • By bhristianzx12
      I have acquired a free 92 Polaris 350L 4X4. Ive replaced carburetor from ebay, replaced spark plug, im trying to pull start but sounds like it doesnt want to fire. Spark is a bright orange spark (checked with spark plug tester), replaced plug, pre mixed gas from an external gravity feed tank. Compression test good. Anyone got any recommendations for me?
    • By jhamrick75
