Artic Cat stutters and I had to keep pumping the gas to keep it running and now it has quit altogether. Have had a mechanic friend take it apart and clean and check everything and it still stuttered. Pulled the cdi box and put it on the other cat and that one ran fine with that cdi box. Any ideas as to what it could be?
    • By oztrax
      MAX 4 6X6 2008
    • By middlebrookgt
    • By PupATV
      -PupATV
    • By bhristianzx12
