i have a 2003 predator 500 and would like to get a set of studded wheels/tires for ice ridding this winter i found on craigslist a good deal on wheels and tires off a raptor 700 i was just wonder if they would bolt up...
or even if anyone knew the predator lug pattern so i could find the raptor lug pattern to see if they match
thanks in advance!
i actually found this very usefull website but it looks like only the front would bolt up =(
http://www.lugpattern.net/Polaris_ATV_Bolt_Patterns.htm
Edited by jwints28
just measure between the center lines of 2 studs side by side the measure to the one across from it. that will give you the spacing. measure the centering opening of the rim and the offset to make sure it will fit. then you will have all of your bases covered.
    • By noticon75
    • By toe420
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
