By 97kingquad
By TravisCr
I don't know if I shouldn't have posted but I this is my second post on this (other was in regionals Forum) The family has a 2-up 2004 Artic Cat and a 2003 Polaris Sportman and we are looking for fun/easy rides in the Colville, WA area- 70 Miles North of Spokane WA, we have a small trailer we can haul these with but need to find some good areas for beginner.
Thanks in advance for any suggestions.
By TravisCr
By JPRICE1981
Hello everyone !! Looking for some help !! Im wanting to check my stator and pick up coil with a ohm meter and cant seem to find a guide that tells me what to read and what my reading should be !! Any help would be great !! THANKS IN ADVANCE !!
By David Cameron
The small waterline insert for the hose that goes from the water pump cover to the thermostat housing has corroded off. I only need the insert on top and behind the thermostat housing that the hose goes over and can't find just the insert. It looks like it may be pressed in. I've have been told the entire motor housing needs to be replaced. The pic with the red line indicates where the hose and insert would be and the insert looks like the pic of the water pump Any ideas would be really appreciated.
