Oil seal on your water pump. That hole is there so you can tell if you have lost the seal on your water pump impeller shaft. The weep hole is sealed off from the water side, and from the oil side where the pump is driven from. Most of the time you will see the water side fail first and water will come out of that hole. But sometimes the oil seal fails and you see oil come out of the weep hole. Behind the impeller, you will see a mechanical seal first, then an oil seal. I would replcace them both. Inspect everything else for excessive wear as well.
Edited by DirtDemon
  • 13 years later...
I’ve got a 99 LTF 500 with a slow oil leak. Have you found leaks anywhere else besides on your machine? I thought maybe the oil plug was leaking. Changed the plug and washer to no avail. Still leaking oil from underneath somewhere. Is a slow leak for sure. I’ll have to inspect the water pump in mine also. Thanks for the info. Regards
    • By 97kingquad
    • By TravisCr
      I don't know if I shouldn't have posted but I this is my second post on this (other was in regionals Forum)  The family has a 2-up 2004 Artic Cat and a 2003 Polaris Sportman and we are looking for fun/easy rides in the Colville, WA area- 70 Miles North of Spokane WA, we have a small trailer we can haul these with but need to find some good areas for beginner.
      Thanks in advance for any suggestions.
    • By TravisCr
    • By jannonballs
      What is this tube for?
    • By JPRICE1981
      Hello everyone !! Looking for some help !! Im wanting to check my stator and pick up coil with a ohm meter and cant seem to find a guide that tells me what to read and what my reading should be !! Any help would be great !! THANKS IN ADVANCE !!
