Please let us know here or at [email protected] if you are having trouble viewing the vidoes in the video section. Please specify what Internet browser you are using and what version. We just want to make sure that everyone can view the videos in the VIDEOS section without any issues.
Thank you
Guest Fox300exchic
There are some sweet videos on myquadvideos.com but I cant upload them from there because its not listed.
Guest Fox300exchic
Do we have to have a list of places we upload from? It can't just be set to upload from anywhere?
Well currently Youtube.com, Break.com, MySpace.com and some others are set up. Google is being worked on since they changed their format. Just hit Upload and you will see a drop down of places to grab a video from.
Guest Fox300exchic
Yeah I know there is a drop down. I was just wondering why. How come we cant upload them from wherever we want?
    • By tflack500tbx
      Background,
      Any Ideas?
    • By jen
      Cannot find out why 12 vdc  4 (4) commutator starter motor has no power. It will run full speed without load. But with any load will not turn. Repaired broken brush holder and insulated an internal wire to magnet that was bare and rubbing. cleaned commutator segments. Ohm readings while slowly rotating commutator was 1 ohm.   When attempting to run  with load it will not turn and Bat vdc only pulls down to12vdc. Cannot find an internal wiring schematic.  I can buy a rebuild kit ~$35 but WTH?
    • By HHurks
      Hi to all
    • By mikeexplorer
    • By Ejwill
