I can't adjust the linkage so that I can shift from forward to reverse. I can either adjust it to shift from neutral to forward or neutral to reverse. What is it that I might be missing?
There are two adjustable linkage rods, one is for low range, the other is for high range and reverse. I would assume that the neutral position is between the formward and reverse positions. So if you can get from neutral to reverse or from neutral to forward, but you don't have enough throw to get all the way from forward to reverse, then I would think you have some excessive freeplay in the shifting mechanism somewhere. It could be the linkage itself, the shift lever, or even inside the gearbox, the shift forks could be worn or maybe the forks are working in overly worn grooves. If you can't adjust to the point where you can hit both gears, I would start inspecting every part of the shifting mechanisms starting at the shift lever itself and check for excessively worn parts.
the shift linkage is an offset system. it will not throw all the way from forward to reverse. the offset is in the the transmission fork system. it is designed so you wont grind the gears or break your trans.
    • By jwh
    • By mans
      Were is the neutral safety switch on 03' Kodiak 400 4x4 . How xan i check it to see if it's good for a no neutral light no power to machine. Ty
    • By gt_jacket
      Hi,
      I have an 04 bear tracker, with a minor starting quirk. It starts in gear with brake in.  Neutral and Reverse lights work.
      All gears shift fine with no issues,  has anyone seen this before?  Just wondering if it is a bad sensor or something needs adjusting.
    • By Coyote251
    • By shawncanam
      I have a 2001 traxter 500 that will  not shift gears the gear selector is blinking 1 through 5  no clue what is the problem anyone have any solutions for this
