well mine wont shift in and out of 4x4 with the top cap spring and pin in if i back it out about a quater of an inch it will shift in and out im not sure what i am missing here , i need help please :aargh:
  • 8 months later...
Where in new york are you i am from ticonderoga , what i found so far the on off valve /filter is not working right i think it works off vacuumm i am replacing it i have had the carb out 20 times at least i have done dyjet kits in all my bikes this one for some reason is kicking my a.... I will check the spring also thanks trying to get ready for the highlifter mud nationals with my 300. Dollar atv project
    • By Elk
      2002 Polaris Magnum 325
    • By tflack500tbx
      Background,
      Any Ideas?
    • By jeffrocdx
    • By MadAdy73
      Hi there, can anybody share or link a PDF for the 1999 4x2 Quadrunner LT-F250 thanks.
    • By shawncanam
      I have a 2001 traxter 500 that will  not shift gears the gear selector is blinking 1 through 5  no clue what is the problem anyone have any solutions for this
