Similar Topics
By Gwbarm
It seems that ATV transmissions are moving more toward automatic these days, I would like to hear other members opinions and experiences, what do you like best Automatic or semi automatic in relation to, power , ease of use, and reliability.
By Kidshavebrokeme
Hello, Im looking for some help instead of spending hours on You Tube. Got roped in to buying the above Kazuma 110 I think. I've worked on all brand of autos.
thought I could tackle this butttt. No start no spark. My stator is producing a faint light by ground. Buy the meter I get 337 ohms on the
black, red wire. Some of my questions, Can I bypass everything to look for spark. Can the plunger type kill switch be removed an both wires put
together to help achieve spark that is behind the seat. My black red to the cdi has no power to it when turning over. Should i put some form of
lubricant in the plug hole or are these motors moving the oil enough and should the plug be in or out or does it matter when looking for spark?
I'm thinking the wire for the coil from the cdi should light up the test light and it does not. (Forget its color at the moment). I hope there's not a limit
of questions cause i will have more and Im not much for typing. Any help would be just jim dandy and greatly appreciated. Thanks Steve
By Matman
First time working with a Honda-Matic transmission. I didn't even know what I was getting into when I purchased this running beat up farm workhorse quad with black oil. I was thinking I could tear the cases apart and find the bad bearing, causing the random squealing noise when you put it into gear and give it gas. Upon opening the engine covers, I Learned about the Honda Matic automatic transmission and realized there's more than just an electronic shift motor going on in these quads. With my learning curve in major education mode, I'm now wondering two possible culprits to the squealing as I've torn the motor down and am staring at the Honda Matic transmission.
Two possible issues:
1. The bearing that is squealing is unfortunately inside the hondamatic unit hydraulic transmission which is apparently not serviceable? A new unit is $1,900 to replace it! Yikes!
2. The pull starter rope snapped and someone replaced with the wrong pull starter rope that eventually became severely worn out and the centrifugal lever/catch shows signs of wear from rubbing against the housing.
Thinking now the pull starter has nothing to do with a squealing that loud, so my attention is now on the Hondamatic unit,
Has anyone gotten inside their cases to inspect the Honda Matic transmission?
There's a only 1or 2 videos out there that are not helpful for tear down and inspection.
I understand it can't be rebuilt but wondering if anyone has looked deep enough into one to clean it out from running dirty oil? Possible identify bad parts.
I refuse to believe Honda is engineeering these as completely non-serviceable?
Thinking I will try to disassemble the Hondamatic unit m. Hopefully get into it and get all the dirty oil out and replace with fresh? Any special tools needed?
Any and all thoughts/experiences with Hondamatic units would be great conversation for me..
By Fiend_138
Anyone using the AtV/Motorcycle lift from Harbor Freight? I like the idea of having something other than jack stands. Is there another option that I should look into?
https://hftools.com/app60536
By Yammy
Can you ride your quad on the road or cross a road if your quad is licensed and registered and you have functional signal lights and running lights?
Let me know, I'm new to this.
Thanks!
Similar Tagged Content
- 6 replies
- 447 views
- 4 replies
- 844 views
- 0 replies
- 2,060 views
- 0 replies
- 2,587 views
- 13 replies
- 5,535 views
Gallery Images
0
4By blahhhh,
3
3
1By newport314,
5
1By myquadrepair,
6
0
2By Ai-noval,
2
7
0
4
6By newport314,
5By monkey420,
3
0
1By giterdone,
0
