2009 Suzuki Quad Sport 400 main fuse blowing.(i read all the suggestions)
billambro
I have a 09 quadsport 400. It's only got a few hours on it. I put an aftermarket exghause on it, drove it up and down the street, shut it off and it would not start again! The yellow 5 fuse blew, when I put a new one in it blows too. It controls my starter and all my lights and is connected under the seat to the battery. I tried disconecting the battery thinking it might reset the computer and work but it didn't. Every time i put a new fuse in it blows right away. There are no pinched wires and I've tried everything! Please help me! This is driving me nuts!
if you are blowing you main fuse then you are shorting directly to ground. it is a process of elimination from there. it will be between the fuse and the part using the power. i would disconect the lights and starter then put in a new fuse. if it does not blow then start slowly connecting the parts back on until the fuse blows thus finding your issue. my gut is telling me that you are shorting through your starter to ground.
Your friendly neighbourhood mechanic.
    • By exalrod
      Hello All !
      Could anyone help with this?
    • By pitts
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By mga
    • By newguy024
