04 quad sport automatic, seems like it is stuck in gear and I can't get in to neutral. Thought starter was bad but I think maybe a neutral switch or something. When you turn it on it says it is in neutral. HELP!!!
The first thing I would do is check all the external shift linkage, since it is easier. There is a small shaft between the gear shift lever and the gear shift shaft, an adjustment there may solve your problem. It sounds like the shift ratchet is working, but maybe it isn't turning the shift drum. If you listen closely, you can hear the gears actually changing inside the gearbox. I would give a listen while you are trying to shift through the gears and try to determine whether you are just hearing and feeling the shift ratchet clicking, or if there are gears moving inside the tranny. There will be more noise and resistance if gears are actually being switched. If just the ratchet is working, the shifter will move more easily than usual, and you will only hear the click of the shift ratchet. If you think only the ratchet is moving, you may need to pop the side cover off of the motor on the right hand side of the machine, this is the cover on the side opposite the gear shift lever. Between the shift ratchet and gearshift drum, there should be a small pin that the shift ratchet uses to turn the drum, this may be broken.
    • By logray
      Hi all,
    • By OldATVowner
    • By HoldenBoy
      Hi all,
    • By crankin
    • By wilmpie
      hi everybody
      I have a kymco mxu 250 automatic from 2006 250 cc  that keeps going forwards or backwards when i shift backwards or forwards an then shift to neutral .
      if i shutdown the motor and push the quad and restart then its in neutral and don't go forwards or backwards, i already checkt if my motor is running good stationairy .
      what can it be or what can i do to fix this?
      thanx in advance
      p.s. Sorry for my bad english it's not my first language.
