2002 Yamaha Raptor 80 cam chain
By Mreoiwerk
Hey, I'm thinking of upgrading my stock sport glide seat with memory foam as a bit of a project. I've seen how some guys use the heavy-duty padding inside the water repellent UTV seat cover fit Polaris Ranger XP 1000 crew for their UTV projects and wanted to try something similar for my bike.
Has anyone done a DIY foam upgrade and have any tips? What sort of foam density would people recommend, and how easy is it to remove and refit the factory seat cover over the new padding? Any advice gratefully received!
By Yamahahahaha
By rjsummer
By middlebrookgt
