2007 Honda TRX450R FULL MX RACE BIKE ( Phoenix)
By umax33
can someone tell me which side the neutral and reverse switch are on a 1986 honda trx 200 The service manual does not say which side, i got the lites pulled out and looked at them and i think the switches are bad. i just don't know which side they are on , the photo in the book just shows how it looks after a cover is off and not which side its on.i would just like to know so i don't have to take stuff off that i don't have to. thanks for any info on this.......
By umax33
i just got a 1986 honda trx 200 and the reverse and neutral lights don't work, i looked in the service manual and it says to remove two screws and the cover comes up and you can check the bulbs, the book does not show the two screws and i can't see them.Does anyone know how to get to the screws to check the bulbs. i will appreciate any help i can get...thank you
By Atomusthenes
By ATVNetwork
The ATV Motocross National Championship (ATVMX) Series, an AMA National Championship, hosted its fourth round of AMA Pro ATV Racing at Lake Sugar Tree in Axton, Virginia on Saturday, April 26.View the full article
By Gwbarm
