2008 Yamaha YFZ 450 Tie Rod Length
By bigbell
Does any know what the stock jets are in the twin peaks?
I bought the bike with a pipe on it and want to go back to stock setup.
By ggreen
Sorry if this is in the wrong section,I didn't really consider it technical or needing advice. 2006,Linhai 300cc.What I was hoping was to find someone with the starter idler gear pin length and diameter. I've had the cover off alot of times and never realised there should be a pin from the case that meets the cover holding the starter gear in place. Now,a deepwell 1/4 in drive,5/16 deep well sits in the pin holes perfectly. Should I cut a lock ring groove in the end of it like a factory pin? I was thinking of just tack welding a washer to the end?
By Airborne
Hey Guys/Gals
going into my second year on new quad , my kodiak is everything and more then expected ; wife loves hers as well. We got the 450 and 700 ... made sales guy smile when we ordered two ... the question i have is the tires , i have heard many say aftermarkets are just much better , iwe use our machines in woods ,and trails and we do ride in snow, with that i think my stock tires suck. The have plenty of tread left but i just think i could be happier with better tires ........id love comments and input
By DracieVajko
Hello, I cant find any solution... The problem is that battery isnt charging.. I located and meassured alternator cable, there was like 100-150Volts in cable that is going to the voltage regulator, but the output from the regulator that is going to the battery, I guess, was without any power, just 0 volts.. So I replaced voltage regulator but didnt helped. On fresh charged battery on turned atv is there around 13.5 volts, when I push gas the volts goes up to 13.6 maximum but the battery still isnt charging, by time it just drops down to 12volts and less again. I have no idea what is the problem here. I would appreciate every help. And sorry for my bad languagge :).
By Otter9099
I am working on a 1996 Suzuki Quad Runner 250 LT-4WD that has been stored outdoors for some time and has old crusty fuel line and vacuum lines. What are the sizes needed for this atv? I don't have a service manual yet.
