    • By bigbell
      Does any know what the stock jets are in the twin peaks?
      I bought the bike with a pipe on it and want to go back to stock setup.
    • By ggreen
      Sorry if this is in the wrong section,I didn't really consider it technical or needing advice. 2006,Linhai 300cc.What I was hoping was to find someone with the starter idler gear pin length and diameter. I've had the cover off alot of times and never realised there should be a pin from the case that meets the cover holding the starter gear in place. Now,a deepwell 1/4 in drive,5/16 deep well sits in the pin holes perfectly. Should I cut a lock ring groove in the end of it like a factory pin? I was thinking of just tack welding a washer to the end?
    • By Airborne
      Hey Guys/Gals
      going into my second year on new quad , my kodiak is everything and more then expected ; wife loves hers as well. We got the 450 and 700 ... made sales guy smile when we ordered two ... the question i have is the tires , i have heard many say aftermarkets are just much better , iwe use our machines in woods ,and trails and we do ride in snow, with that i think my stock tires suck.  The have plenty of tread left but i just think i could be happier with better tires ........id love comments and input
    • By DracieVajko
      Hello, I cant find any solution... The problem is that battery isnt charging.. I located and meassured alternator cable, there was like 100-150Volts in cable that is going to the voltage regulator, but the output from the regulator that is going to the battery, I guess, was without any power, just 0 volts.. So I replaced voltage regulator but didnt helped. On fresh charged battery on turned atv is there around 13.5 volts, when I push gas the volts goes up to 13.6 maximum but the battery still isnt charging, by time it just drops down to 12volts and less again. I have no idea what is the problem here. I would appreciate every help. And sorry for my bad languagge :).
    • By Otter9099
      I am working on a 1996 Suzuki Quad Runner 250 LT-4WD that has been stored outdoors for some time and has old crusty fuel line and vacuum lines. What are the sizes needed for this atv? I don't have a service manual yet.
