By jen
Wow...I packed a small soft side cooler with an ice pack at -4 F and inserted my Type K thermocouple sensor inside so I could monitor the temperature without opening. After 3 hours the inside temperature was 60 F...OMG! The ice pack was solid frozen. Standard temperature for safe storage is < 40 F. What I found by asking was that there should be no air space in the cooler. Packed with Ice preferably ice from connivence store (normally 0 F of less). Food should take up short day trip1:1 ratio.
Good coolers are expensive.
By realpilot
By LashinWheeler
Any help would be great,
Thanks!
By OldATVowner
By mikeexplorer
