pete59edsel
Our Weekend relaxers!
The Far back one is a Can-Am 650, next to it is the Yammer 200, Then the Eiger400, followed by the 300 Bayou. It is good to just be able to go on weekends or time off, keeps me from going insane!! LOL :aargh:
Share this post
Link to post
Who says that your allready not insane !!:laugh:Nice toy collection !!
Share this post
Link to post
  • Similar Topics
    • By Brother Buddy Gardner
      Hello everyone! I recently purchased this quad for a mere 300.00 and it is pretty clean for the year. I bought it from a guy who bought it in a storage unit. He didn’t know anything about it. I got it home and noticed it did not have an ignition coil for the spark plug. I bought the ignition coil, a new battery, new CDI box, new starter relay, new safety neutral relay, new carb and so on... I got it to turn over, but when I pull the plug and check for spark I have nothing.. it has a non factory starter button that works when I push it and turns the engine over no matter if the key or stop switch is on or off..not sure what that’s all about, but it does turn over..just no spark at the plug. Any help would be greatly appreciated! Thanks!
    • By Michael Kastanis
      Hey I have a Kawasaki 300 boyu and it die in 5 gear and can’t get in Neutral try rocking it and moved it back and forth but nothing can same one here help me pls
    • By Tom Pavlak
      Hi Everyone - Need some help.
      Got a nice little 220...clean machine. wiring is a mess. I have a diagram however, the one I have has 4 wires coming from the ignition switch not 2 like mine. So, I cant trace wires properly.
      There is a white one that runs to the Solenoid, and a brown wire...from the Ignition...I dont know where its supposed to go. Also, on the Solenoid, there are 3 wires..W to ignition, B to start relay and B/Y runs up to the front of the machine...and is not plugged into anything...and there isnt a "Mate" missing it. How do they plug into the 4 open shovels by the 20A fuse?
      I'm pretty sure my Lights and start switch/Lights are correct.
      Problem I cant get anything...new battery...cant get the start button to work, cant get any power to the lights or switches...so I know something is not grounded or..
      Any advice would be greatly appreciated.
      Tom
    • By 1911Neil
      I had a quad fall in my lap a couple weeks ago. The only things I knew about it was it was a Kawasaki Bayou 220, was in pretty rough shape and was free. I couldn't say no to a fun little project. I've been looking a different ATV forums gathering quite a bit of info and decided this was the one I wanted to join.
      Thanks to this forum, I found the VIN under about an inch of mud and cross referenced it to be a '98. It had been sitting outside for at least 5 years and was told it ran when parked, but had no brakes. Squirrels or mice had been chewing on the handlebar controls and it's generally just kind of beat up.
      So far, I've gone through the carb (not near as bad as I expected), freed up the brakes (will probably need new cables), replaced the spark plug, air filter, petcock and put a new battery in it.
      The gas tank had been empty and looked clean so I put some fresh gas in it and tried to crank it today. I got a neutral light, but the starter button did nothing. I tried pull-starting it and it wouldn't fire. I checked the plug and wasn't getting a spark. I started digging and found some potential issues and some definite problems.
      I have a wiring diagram I found on here but it's just a picture or scan out of a book and hard to read. I don't see a reference to a black/yellow wire, which is my first problem.
      First, it that a factory crimp? One of those wired looks like it goes to the connector in the 2nd pic. Is that just a spade lug type connector? I pulled on it with some needle nose pliers but it didn't seem to want to come off. In the 3rd pic, should there be a fourth wire?
      I've read through and bookmarked the threads Andrew Baker and Arizona have going but I figured I needed to start with these obvious issues first. I have lots of pictures, so if there is something else you want to see, just ask. If I don't already have a pic, I'll take one.
