Alpinestar Tech 3
By DarkRider
By mga
I have to replace all 4, how much is involved? Will they slide out of the front yoke? Or, do the boots just slide over the wheel end?
By huntindog
TIA
By Frank Angerano
By prdicon
South Florida.
How much it worth?
Pros: looking decent.
Cons
No brakes.
Front wheel bearings are shot.
Idles, but sometimes will shot off. Most likely when cold.
Gas smell and little bit steam in the air filter box when I started it.
Display screen won't work.
Tires are dry with cracks.
Not sure if has title, I will check and update.
How much do you think it worth?
