By umax33
i just got a 1986 honda trx 200 and the reverse and neutral lights don't work, i looked in the service manual and it says to remove two screws and the cover comes up and you can check the bulbs, the book does not show the two screws and i can't see them.Does anyone know how to get to the screws to check the bulbs. i will appreciate any help i can get...thank you
By docdoug72
Has anyone had a suzuki 230 quad lock the engine up? Its a well maintained bike, it locked up when my son was riding it. Pulled the plug, it has connected with the piston. I'm thinking the con rod let go. I don't have a service manual. Does the engine need to come out to check further?
By Atomusthenes
By Tim Keiper
By BuckBilly
