I just purchased this wheeler for cheap. When I got it home it started hard, and when I did get it started it would rev very high in neutral after warming up for a minute also it would do this in gear. It would rev back down when put back into neutral. After shutting the machine down and letting it sit for about an hr it started hard again and when it did finally start it rev right up so I shut it down. Now I can not get it to even start at all after sitting for a day. It did back fire twice yesterday but that was it. I am getting spark and gas choke cable is broke and I notice the air filter is not in. so where do I start. Put a new plug in and that is about it...carb looks really clean...also how do I remove the choke cable and throttle cable from the carb...new to all this atv stuff but good with a wrench and hope to be able to do all this myself...thanks guys
Welcome to QC !! What model are we talking about ?? is it the Arctic Cat in your profile ??
Welcome to QUADCRAZY!
1. Get that choke working, replace the cable if needed.
2. Secure/Replace that air filter
3. Replace the spark plug
I think the issue is mostly that your choke is not woking and you've got an incorrect air/fuel ration at different engine temperatures. The plug could easily foul if it has not already.
* Moved thread to Suzuki forum, added manufacturer and issue to thread title.
Do you any history of the quad ? Has it been sittin for a while or ridin from time to time ? I would still tear apart the carb and clean it for starters ! Like Ajmboy said fix the choke cable !! :yes:
The wheeler was rode once in a while been sitting for a few months though. took the carb out, choke cable was froze up and and snapped now....also noticed the side cover is missing that covers where the throttle cable sites in side the carb....no markings on the carb besides mikuni corp..can anyone tell me what model carb came on these machines...again thanks guys
Got the wheeler running..thanks guys...only one more issue...on the rear brake the stud that rotates to lift the pads isn't turning that much when the brake pedal is pressed...doesn't look like it would lift the pad far enough....how much should it rotate and how do I make adjustments so it does turn enough tolift pads the proper distance?
    • By wilmpie
      hi everybody
      thanx in advance
    • By T37Mark
    • By joezee13
    • By middlebrookgt
    • By Olchap
      Hi, I am new to  this forum and I am happy to be here.  I purchased a Yamaha 350 Big Bear without a title and I cannot find a Vin number to find out what year it is.  I am hoping someone here can help me identify this atv. I checked on the main frame near the front A-arm left side found nothing.  I checked up near the radiator and found nothing.  Where else should I look?  See image below.
