i took apart the rear disc brake (cover,disc,caliper,pads) and when i was putting it all back together, i noticed the disc on the spline was not secured by a lock ring or anything. i looked at schematics and there is nothing holding that disc on. is this right? seems like a poor design to me ....
    • By vaneleus
    • By Olchap
      Thank you,
      Olchap
    • By RussB
      Has anyone found a rebuild kit or an aftermarket replacement for the original which costs 500.00 US dollars?
    • By Rickm59
      I have a 2022 Kymco MXU150 and have been trying to bleed the rear brakes for several days. I have used a vacuum and also tried the lever pumping. i took the caliper off and compressed the piston with a C clamp and had a tight brake lever. I put it back together and still cannot build any pressure in the brake system. Any ideas from anyone?  Thank you
