i took apart the rear disc brake (cover,disc,caliper,pads) and when i was putting it all back together, i noticed the disc on the spline was not secured by a lock ring or anything. i looked at schematics and there is nothing holding that disc on. is this right? seems like a poor design to me ....
    • By vaneleus
    • By Olchap
      Thank you,
      Olchap
    • By RussB
      Has anyone found a rebuild kit or an aftermarket replacement for the original which costs 500.00 US dollars?
    • By Rickm59
      I have a 2022 Kymco MXU150 and have been trying to bleed the rear brakes for several days. I have used a vacuum and also tried the lever pumping. i took the caliper off and compressed the piston with a C clamp and had a tight brake lever. I put it back together and still cannot build any pressure in the brake system. Any ideas from anyone?  Thank you
    • By mga
      on my left brake handle (for the rear brakes) there's two wires attached to it. What are these wires for? They can't be for the tail light, since it only has on filament  I tried to trace them, but i got lost in the harness. I checked wiring schematics, but didn't see anything like that.
      I'll post a pic later.
