My Warrior seems to have a high idle. When I turn the spring loaded screw out it idles down but then the engine will start backfiring through the carb after I ride it for a little. It will die and have trouble starting after it's warm. The screw below it I think is Air mix screw but I can not screw the screw in or out. The screw below it may not be the air screw but I can't see any other screw.
    • By realpilot
    • By Elk
      2002 Polaris Magnum 325
    • By OldATVowner
