it is a 99 mojave bought it couple weeks ago and it would run i relaced some stuff in the carb like the needle and seat and one of the jets put new plug in it and now it runs good until you rev it way up like wide open throttle then it misses almost like it is hitting a rev limiter could it be that it needs a new carb gasket or what are some ideas that could be wrong with this thing
did you get the manual? If you didn't, go to the kawasaki forum on here and look for the thread " help...my 2000 mojave won't start" and jonny450r posted the actual manual you can download...they have a troubleshooting area in the manual ...what do you mean by "Missing" at WOT? Backfiring or hesitating?:huh:
    • By 97kingquad
    • By Does_This_Look_Bent?
      Hey everyone, I just replaced the carp on my 98 Kodiak 400 with PN#4SH-14101-00-00. It starts and idles perfect, but once it’s good and warmed up, it bogs out at 3/4 throttle or more… it sounds like it’s bouncing off a rev limiter haha… I tried the air fuel screw, all the way in and out 2-1/2, and it made it a touch better… tried 2 turns and no different. Am I missing something?
    • By Chucksta
      Any ideas?
    • By justent_88
