Thanks guys! I'm getting into photographing ATV's with this season's Worcs series. I'm hoping to go to all the races this season and provide coverage. Do you guys have anybody on here that race in this series?
      We've relaunched our Facebook page in an attempt to grow our social network fan base and to raise awareness of QUADCRAZY on the largest social platform in the world. Become our fan to get the latest updates about contests, news, and more from this community.
      Visit http://www.facebook.com/quadcrazy and click the "Like Button".
      We're going for 1000 fans for now.... You can currently watch the count grow on the top right of any page on QUADCRAZY. Currently at 123. Help support QUADCRAZY and spread the word!
    • By middlebrookgt
    • By roggers
      Hi everyone,
       I often work on both ATVs and larger construction equipment, and I’m always on the hunt for solid OEM manuals—service, repair, and parts. The usual searches give a lot of random PDFs or unofficial scans that aren’t very trustworthy.
      What online sources do you all use when you need a factory manual quickly? Are there sites you’ve found that consistently provide genuine OEM content for ATVs or heavy machinery?
      I recently came across Heavy Equipment Manual, which claims to provide verified OEM service and parts manuals (covering brands like Caterpillar, Komatsu, Kubota, etc.). Has anyone here tried it, or do you have other go-to resources you’d recommend?
      I’m interested in options that are:
      ·        Fast to download
      ·        Cover both heavy equipment and ATV models
      ·        Clear on licensing and safety
      Thanks for sharing your experiences and any recommendations!
    • By marcosphoto
