1997 Polaris Xplorer 500 Starting problem
Mchenrymac
I have a 97 Polaris xplorer 500!the other day I took it out for a ride then loaded on trailer and took it home. The next day I went to start it and it wouldn't start!starter is spinning but that's it.i removed started then reached in with my finger and was able to spin gear inside engine with my finger!! Any clues as to what the problem may be? Thanks
    • By HondaRubi2022
      Hello,
      I have a 2022 Honda Rubicon and I have an issue where it won’t start, when I turn the key for power nothing lights up and it won’t start but the lights will turn on with the light switch, I’ve checked all fuses and they’re good, I don’t have a wiring schematic I’m not sure where to start, I checked the ignition fuse when I turn the key on and there’s no voltage there, I used a jumper wire from the batter to the top of the ignition fuse and then it works fine and starts fine but as soon as I turn the quad/key off it won’t start again until I jump the ignition fuse with battery power, just wondering if anyone could give me some tips where to go with this or if anyone has had the same issue, thank you.
    • By blacktrain11
      2000 Suzuki will not fire. Fresh fuel, new plug, has 170 pounds of compression, super hot blue spark, won't even fire if you put fuel directly into the spark plug hole. Carburetor has been cleaned. Any ideas? Thank you...
    • By jmercer
      Wondering if 1997 klf400b has a decompression, I’m getting 90psi on gauge.
    • By justenmiller09
      I just rode my klf 300 all day yesterday, and today when i went to unload it it would not start. When i took the plug out to check for spark it only produced a very faint weak looking spark and it was not consistant with rolling over, is this from a bad ignition coil or could it just be a loose conection somewhere?
    • Sell your car with CarBrain
    • By oxidized_black
