Has anyone out there had any charging problems with the 400cc outlander max?I have one that is not charging have checked the stator and reads ok.Not sure what the specs are supposed to be for voltage coming out of the stator to the voltage regulator.Does anyone know what I am supposed to have or were there any problems that these units are prone to?The factory part is over 500.00 they want to sell you the flywheel with the stator.I haven't took the engine apart yet was hoping someone could give me a tip as if they had flywheel problems or something in that order.Please advise? Don
No the battery has already been changed.Its not showing any voltage coming out of the stator but the stator checks good with my Fluke.Just wondering if they had issues with the flywheel or not.Don't want to tear the engine down unless I have to.I will check out the manual Thanks Don
    • By toe420
    • By Coyote251
      I am hooking up a speaker on the rear of bike and want to use a factory auxiliary switched plug and not have to cut into the factory wiring or add another switch. I have read a bunch of posts that say there should be an auxiliary 12V connector in the front and one in the rear. I found the one in the front when I hooked up my winch but cannot find any in the rear. I have seen some pictures showing one on the right side attached to the down tube behind the side cover, but there is nothing on my 2024. Can anyone confirm that there is a auxiliary 12V connector in the rear on the 2024 700 Xmr? If so, can you please tell me where it is (with a picture if possible)?
    • By Rockbottom
      any ideas how to correct
      thanks ahead
    • By Callaway
