    • By Matthew Alloway
      What is the best paint for a swing arm. I know powdercoat would be the best, but I am looking for paint type that I can easily do at home.
    • By mga
      So, i go to change the oil in my 2k Y 400 BB and, without reading what types of oil to use, i just put in 10w-40 motor oil.....then i decided to read exactly what type of oil i should be using. Apparently, the ATV oil is designed to also work with the clutch..lol...which is probably  why i was having a few issues going into the gears, or, maybe losing 1st gear going down a hill. Ok, now that i got educated i bought like 6 quarts of the "special" oil required.
      Now, my second issue is it was hard to start for some reason. Usually it fires right up. So, once started i brought it up to the garage and removed the seat, thinking maybe the battery was weak from sitting. Nope...12.5 volts, but.....a mouse decided to build his nest right on top of the battery. I cleaned that all out, but, when i went to start it, the solenoid clicks and the starter just spins. UGH. One thing after another. No wires were chewed thankfully. Just kind weird the starter would do that all of a sudden when i messed with the oil.
      Do i need to pull the starter now and check the bendix thing? It spens real nice, it just won't engage. The wrong oil wouldn't do that...would it?
    • By cosmacart
      Hi all, iam from ohio and i have a 2013 yamaha rhino SE black . I might sell it but i dont know what its worth. So can anyone give me an idea what to ask for it?? This is not a scam,,its only a question thanks in advance!!
      Does anyone know of a safe paint stripper for ATV plastics other than Permatex, I can't seem to find that one in my area.
    • By Wookard
      I am not sure if there is a part number or a name for the end covers to make it easier to look for replacements on these.
      Missing both so would be nice to see if there is actually a replacement part for just the covers.
