Hi every one new to this forum i have a problem with starting it idles ok but as soon as you open the throttle it dies i do not have a manual yet only hand book can anybody help it has been running fine up and till know
Graduc
I would check to make sure the choke is working properly and not stuck open. Also make sure the ATV is warmed up before you try and drive off. If those two do not help I would say check make sure the airbox is not blocked and the gas is good. Cleaning the carb would be a last resort.
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
      Sportsman 1000 wiring diagram
