Guest Fox300exchic
They have videos like that on a show on MTV called Scarred. Pretty wicked. Bones breaking and coming outta guys arms and stuff.
    • By Chucksta
      Any ideas?
    • By mga
      I just saw a video on TikTok where some guy took the rear end off an ATV and bolted on a roto tiller in place of rear wheels. I wish i saved that video to post here....good thing it was 4 wheel drive...lol but, it seemed to work.
      I'm not sure how he made it bolt on to the drive....
    • By WHALErn
      I ordered an ATV through ElectriRide a ( Pioneer 1500w Power E-Grizzly Electric ATV ), on February 13, 2024.  They ( ElectriRide ), ordered it from the manufacture on February 28, 2024. Not sure when it shipped, but it arrive here at my house on June 25, 2024.  I live in Hawaii.
      Unpacking it, I quickly became aware that this was not the ATV that I ordered.  The package had some damaged, but not major.  After unpacking it, it was very obvious that this was not the ATV that I had ordered, plus it was missing some a number of parts, namely the rear rack & no instruction or electrical circuit layout, just to name a few.  A couple of days later I found ( 2 ) small two burnt holes in the upper frame, right side, also.  Several days later I tried to charge the batteries on the ATV, after plugging it in for over 4  hours, “NO CHARGE” , I checked the charger’s output voltage, it read “ “ 0 “ volts, the charger needs to be replaced also.
      The next day, I reported all of this to ElectriRide, & they asked for photos, which I later that day send to them.  They said they would look into it and get back to me. For the last 2 1/2 weeks, I have been calling them (playing phone tag ) & emailing them, basically getting the same message back from them.  They sent me e-mails “ we will get back to you “ or “ Please rest assured that we are committed to resolving this matter to your satisfaction. “.  As of today, that message was 10 day ago, and it’s been 3 weeks after receiving the wrong ATV.  And 5 months from the time of ordering the ATV.
      The ATV that this looks the most similar/closest to the one that I received is the ( Pioneer 48v 1000w Adult ATV Electric ) in their catalog, but there are a number of differences to it also.  ( Mostly it’s a 1000 watts motor, not a 1500 watts motor ATV, plus a number of other things also ).  The suspension & wheels are completely different, along with some of the electrical components, and it was missing the rear rack also.  Along with some other minor things.
      I seem to be getting nowhere with communicating with them, (ElectriRide ) in getting this mix-up / changes resolved after calling / emailing them pretty much daily for over 3+ weeks, I am turning to you, the ATV community for any suggestions for helping me to solve my problem.
      Please leave any suggestion / ideas, you thing might help me solve this problem, or who to contact that might be able to help..
    • By Bobbywolf
      I am working on a basket case for a friend.  It is a 98 Big Bear (YFM350FWB).  It came with a parts machine which is a 96, which I am coming to find out is VERY different from his machine.
      Anyway, first thing is first.  I checked compression, 150psi.  Valves are set correctly, and the engine is in time.  I cleaned the carb, and there was some junk in the passages.  It is a chinese carb, which I figured from the lack of markings or lettering altogether.
      The bike runs.  It idles ok, but breaks up badly under acceleration.  Pulling a new spark plug shows it is running lean.  White strap, with no black whatsoever.  So I have the carb adjusted with the mixture screw out way too much (about 5 turns), and the diaphragm needle lifted to the top slot.  It is still not getting enough fuel (or too much air).  It backfires through the carb, and cannot get above idle without carrying on.  The carb boot is in good shape, so it isn't pulling any air there.  I did test this as well by spraying ether around the boot when running, looking for intake leaks.
      Anything big I am missing here?  I am starting to believe that this chinese carb is the issue.  This quad came with the original carb, which I would like to rebuild and use, but the mixture screw is totally stuck, and stripped way down in its recess.
      Thanks for any assistance.
    • By Werewolf
