my wife has a 2007 honda trx250ex we shut the bike off went to start back a little later and had nothing. The neutral lite wouldn't come one, pushed the starter button and nothing happened. i was able to jump across the solenoid and fired right up. I pushed the starter button while it was running and i kicked in lights all worked. Then turned the key off and nothing works. If anyone has any ideas it would be appreciated.
thank for helping. i should of waited a little longer be for i posted this. i new there had to be a fuse some were and i finally found it and that was the problem
    • By umax33
      i just got a 1986 honda trx 200 and the reverse and neutral lights don't work, i looked in the service manual and it says to remove two screws and the cover comes up and you can check the bulbs, the book does not show the two screws and i can't see them.Does anyone know how to get to the screws to check the bulbs. i will appreciate any help i can get...thank you
    • By docdoug72
    • By Atomusthenes
    • By Trent Finnessey
