Hey all,
so i am about to start a project of getting a 2004 Kazuma Dingo 150 back to working after it has not been turned on or touched really in 2 years. i couldnt find any forums on this or help on google.
I want to flush the fluid systems; oil, brakes, gas, etc. im curious as to what the best way to flush the system and clean them internally im new to the whole ATV scene as well as im not an expert mechanic or anything. Id like to get the internals clean but dont want to ruin anything either. Just curious what you guys do and what works for you and especially what i should stay away from doing.
Hey all,
ive had to do this with several mowers, quads, and a couple boat motors..... wat i always do is completely drain everything... change the oil filter and clean out any screen mesh tht is in the lines for filtering...... after tht fill her up with new everything and fire it up..... ride it around for a lil bit to get everything circulating then drain all out again and fill back up.... after tht it should run pretty clean.... as for the fuel... buy you some fuel cleaner at a gas station and dump the correct amount in shown on the bottle.... tht will flush her out pretty good..... i always use "marvel mystery oil"
LOL thanks Jerod :laugh:
    • By realpilot
    • By OldATVowner
