Thanks for the help. I just relooked and noticed the last 10 digits are etched, 1st 7 are stamped / printed on the plate like so:
vin LW0XCDG xxxxxxxxxx
Thanks for the help! Now I can get them regd / green stickered. Yippee!!! :biggrin:
    • By hunky
      This old boy has been coastal so lots of rust. But when I turn the key, nothing. Green neutral light works, head/tail lights work. Was running fine when I parked it for a few months.. no issues with starter. This did happen once before (last year).. not sure what overcame it.. maybe playing around with gear shifter.. but not sure if that was what did it. But doesn't seem to do anything now when I play around with it while hitting the start button.
      I did take apart the handlebar mounted start button housing and looked it over. Couldn't figure anything out there, but looked the same as when I had the problem last year. Put my probes on various wires there but didn't learn anything.. not sure how it is wired.
      So this first image there is a connector with 2 wires coming from forward (the male part of connector) - one blue and one blue w/ red stripe. The blue continues down to a post near where the gear shifter enters the housing. (Second image). I was wondering about that.. I opened up the connector and the 2 wires (coming from forward) show continuity when I put my probes on 'em. Thought that was weird, but maybe supposed to be like that? I turned on the key and tested for voltage but didn't find any.
      I'm just unaware of how to test for anything. Would be interesting to put 12 volts to the starter, but not sure about doing that or how. The wires going in are kind of hard to get to. I suppose I could take out the starter.. but wanted to ask if there is something easier to check first.
      Thanks for looking!
    • By carkivey3
    • By killerklown
      I received an additional parts engine with a 220 Bayou I purchased, but I believe it's a couple years newer than the ATV, Is there a way to decode the engine serial number like we can with VIN numbers?
    • By afterdinnerspeaker
      Hi Everyone!
      Recently, I could no longer start my Arctic Cat using the green starter button.
      Initially, the response was intermittant (sometimes it would start and other times in wouldn't).
      Finally, I get no response or sound by pressing the green button.
      I'm trying desperately to trace the wires from the green button but can't seem to follow.
      I took the button apart and cleaned the contacts but no difference (yet my instruments indicate contacts are OK).
      I inserted an image to show the wiring colors going into the green switch.
      I'm still able to start the machine by using a long screwdriver to short the starter.
      I'm hoping someone can help me find a possible break in the wiring or any other cause.
      Many thanks in advance to anyone who can help me!
      Jerry
    • By Mech
      View File Kazuma Mini Falcon 90 Deluxe Owner's Manual
      Submitter Mech Submitted 07/29/2023 Category Kazuma ATV
