For some reason QC e-mail messages was going into my junk mail. I thought it was strange not seeing anything in my e-mails. I'm still trying to find a good deal on a radiator for my quad. I have not had the time to take mine out & try to get it to a radiator shop to see if they can fix it. I thought about taking it out to day but it was 106 deg. outside I'm not in that big of a hurry.
We have been wondering where you been !! glad to see you back on the forum :yes:
  • 5 weeks later...
    • By exalrod
      Hello All !
      Could anyone help with this?
    • By Topendcol
      First issue was fuel pump wont start once ignition has been turned on. Replaced the pump as I had one on hand, than noticed no power so replaced the fuel pump relay as that was were i traced the power to. Still nothing so further inspection looks like signal is coming from the PCM (FLR B20) but not switching the the brown wire to the fuel pump. Ive checked the operation of the bank angle sensor and it appears operational. Fuses and wiring all appear OK. The engine stop relay also tests OK. Ive been through the repair manual and diagrams but to no avail. Fully stumped, any tips would be helpful. Thanks
      Col
    • By Cheetah
      Hello,
      recently I removed my starter because it was to slow so before buying a new one I thought cleaning it. So I did and it did went much better.
      The thing is I replaced it exactly as it was but since then the starter goes freely like there’s no dentelywheels.
      Did I do something wrong ?
    • By Mikael
      I recently bought and old Kazuma Dingo 150cc and to begin with it started just fine. Then, for no apparent reason, it wouldn't start. It turns the motor but fuel isn't getting to the spark plug.
      As mentioned in the title I've since replaced the fuel filter, the carburetor, the ignition coil and the spark plug. Fuel comes into the carburetor but seems to go no further. Is it a vacuum problem? Does anyone have a good idea about how I could diagnose the problem? And how to fix it?
      I don't know what year it's from, sorry.
      Sincerely
      Mikael
    • By fordsoll
      I have a 96 Kodiak 400 that suddenly died and didn't start back up again I replaced the cdi and ignition coil and now when I check for spark it is very good but when I put the plug back in the engine to start it it does not start so I checked for spark again and it only sparks every few seconds instead of what it did before. The engine will run if I don't check for spark and just start it right away but I don't know how long because it was just running on wd 40.
