No clatter all smooth
if its sucking air through your tail pipe i would check and see if when u try and start the bike if the carb pushes gas into the breather then you know their is either a whole in your piston, rings are shot, or your intake valve is stuck open and the head is pushing air instead of sucking from the carb and out the tail pipe. compression problems could be as simple as no plug in the bike bad piston bad rings anything of that nature check your carb and see if its pushes gas into your breather when you try and start it then let me know what happens.
    • By mehim
    • By LCP92
    • By DexKing
    • By MOORETARHEELS
      I have a 2006 LT 80 done a top end rebuild and only have 80psi.  Any suggestions on what it could be.
    • By xxjeanxx30
      so i have bought a quad (1985 suzuki LT250E) and the quad had the wrong spark plug and was not tight enough I now have dirty tread and a compression leak what would be my best option try to force the spark plug or take a tap and clean the tread ?
