2009 Honda TRX450R - Plz Help ...
By marlon smith
By kevinohio
By Rick Shropshire
I recently picked up a 2000 warrior 350 and it doesn’t have the air filter box so I was thinking about using a clamp on filter directly on the carb. Anyone know what I need to get or where I can find it? The one I ordered goes in the box and won’t fit directly on the carb.
By Asand211
I've got a 1995 220 Bayou and the electric start does not work. When I got it the machine was pretty rough but I was told it ran less than a year ago. The key switch had been cut off and wires twisted after the key was lost. I bought a new ignition switch and repaired the wiring and it is working correctly. It is in neutral and the neutral light is on when the key is turned on but I get nothing when pressing the start button. I verified there is no voltage going to the starter from the solenoid. The fuse in the solenoid is good. Something I found that is odd is that I get positive voltage(12 volts) to the brown, black, and white wires that run into the solenoid when the key is on. That doesn't make sense to me but I could be wrong. I would appreciate any help I can get. Thank you in advance.
By 97kingquad
