The Right ATV Tires Are Essential
If you have not noticed lately, the most recently craze is racing around tracks, up the side of hills or through dense woods and forests. The all terrain vehicle, better known as the ATV is becoming more and more popular among racing enthusiasts around the world. And, of course, there is no better place than in the Unites States to be able to pursue this hobby. Now, you are wondering what makes the ATV so special. The most defining feature of the ATV is that it has four specially designed ATV tires.
Okay, so now you are thinking—four ATV tires. They are just tires, but you would be wrong. The ATV tires have been designed to be wider and to have less air pressure. They are studded tires, also known as knobbies by ATV enthusiasts, that can withstand jolts and shocks that would flatten an ordinary car or motorcycle tire. The ATV tire is very special.
Whether your passion is winding, backwoods trails, rolling sand dunes or wide-open fields, the ATV tires give you the handling and performance you want from your ATV. The ATV tires allow the rider to drive over all kinds of terrain in all kinds of weather. When the snow begins to fall, the roads and trails get slippery. This is no problem for ATV tires and they can maneuver through these weather related problems with no effort.
Many people get very upset when they spend thousands of dollars on a new or used ATV but discover that it does not drive the way they expected it to. The problem may not be your ATV or your driving skills. The problem may be that you need is a new set of ATV tires.
It is important to remember that the ATV tires should be replaced when the nub elements begin to round on the edges. New ATV tires will give you the extra assurance that you will need to make it through a sharp curve or up a steep hill.
In order to develop a better understanding of the features, benefits, sizes, and specifications to look for in ATV tires, you may want to do some internet research. There are many different ATV tires that are available. You need to determine which ATV tires meet your needs. Are you only driving your ATV on paved tracks? Or are you driving through very rough terrain and need the extra gripping action that some ATV tires have?
ATV Connection Magazine has many press releases discussing the new ATV tire arrivals and these articles can be useful if you want to stay informed of the latest updates in the ATV tire market.
You want to make sure that you buy the correct ATV tire for the type of driving you do. Nothing is more important than your safety and having the correct ATV tire will help keep you safe. So, get your ATV tires checked and replaced them if necessary. Then go out and enjoy yourself by riding through the rough terrain knowing that you ATV tires will get you where you want to go.
  • 4 years later...
    • By jay41198
    • By bradleyheathhays
      Unfortunately it looks like I have some people in my new neighborhood paying a little too much attention to my auto and for the first time I'm feeling a need to add some security system(s) to old yeller.  I think just a basic remote arm system would do, not interested at all in remote start or unlock.  I'm not familiar with modern alarm systems, but here's what I 'think' I need...
      - Door switches for all 5 doors (rear hatch).  Probably a PITA to install but that's only an initial idea.
      - 'Bump' alarm (not sure what it would be called) for if a window breaks or if something is jarred
      - Geo-location function like a low track or something similar
      Additionally I'd like to install possibly 2 start kill switches.  I'm not sure where inline these are normally installed but my impression is that directly in line with the key ignition switch would be common.  But then what if someone jumps the starter with a screwdriver...would this type of switch work in that instance?  So that leads me to the idea of a second ignition kill switch which would either be wired between the battery and starter motor, or between the starter motor and ground.
      And last...security lugs.
      So am I over thinking this here?  What's your recommendation for what I really need and maybe a good but economic alarm system that can get this done?
    • By quadmaniac
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
