I took the cover off the pulse generator, It looks like someone threw a handfull of rust in there. Can someone tell me what is going on. And how to keep this from happening again. Thanks Bruce
the stator cover? more than likely it has been a build up from over the years (30) and has let go and freed itself up. the stator usually gets a little bit of oil from the crank. maybe from more use you have been putting on it, it has just fallen off and will be ok now if it got cleaned out. hopefully the stator is still ok ....
The pulse generator is located on the left side of the motor near the top of the cylinder. It rotates on the same shaft as the cam. Driven by the timing chain. Bruce
    • By Ejwill
    • By Coyote251
    • By DaveswMN
      Thanks for any thoughts.
