Race Built 400ex ( Des Moines)
By logray
Hi all,
By quadcrazy
QUADCRAZY NEEDS YOU!
By quadnut20
Just picked up a 2025 Yamaha Kodiak 700 fixing to do a EPI Clutch mod to it since I dropped bigger tires on it !! Air box , exhaust , and programmer next !
By Louznmemind
I know this is a stupid question but here I am.. I'm wanting to have the ability to disable my taillight/brake light on my '96 Polaris Xpress at will, it comes on with the key and there are times I don't want it to illuminate. I have basic wiring knowledge and I'd like to put a toggle switch to disable it. I'm not sure of the wiring setup on this thing, can I just use a toggle switch on the ground wire to kill it when I choose? Can someone clarify which wire I need to work with and the easiest way? Excuse my ignorance yall.
By sunn
The clutch engagement on my 2021 cforce 400s was approx 2700 RPM, very abrupt/not smooth. I obtained a "kit" from RNG consisting of a blue painted spring (spring force unknown) with 12 gram weights, as measured on my postal scale. Installation was easy; 18 mm and 30 mm (not 32 mm as seen on other writings) impact sockets for clutch housing removal. The resultant clutch engagement was still up to approx 2500 and very abupt/not smooth.
The original spring was labeled p/n 0951-1021 (specs for spring force 300/1600) with 18 gram weights.
I called RNG who told me the kit should work fine for my ATV, but that wasn't the case as I found.
The RNG spring was slightly longer than the stock spring, but felt slightly easier at initial downward force but had more resistance than stock as I continued to push down. RNG would not tell me what the spring force was.
I then tested the clutch with the RNG spring and the OEM 18 gram weights with the resultant engagement RPM of about 2050 RPM, a little smoother engagement but still not good.
I am really struggling to get any answers on the best combination of spring / weights to achieve a smooth engagement of maybe 1800 RPM. Note; idle RPM is approx. 1600.
I have searched all the forums and cannot find good information, and RNG appears to be not willing to share information. What gives here? Anyone with experience to share?
