Similar Topics
By Susan Makowski-DeGraw
My quad runs, it starts up runs for about 10 minutes and then it dies if you let it sit for 10 minutes it’ll start back up ride for another 10 minutes and then die again, trying to figure out why it keeps stalling
By quadcrazy
QUADCRAZY NEEDS YOU!
By JacobSlabach
Hey I picked up a pit bike and a foreman for 800 the pit bike was running but the foreman was locked up. Sold the pit bike but when I took the top end off the piston I only found half a piston left. So knowing the rest of the piston was down in the crankcase I knew it had to be pulled and gone thru completely.
to pull the motor I went ahead and pulled the rear end off and unbolted the front diff to pull the drive shafts and pull the motor. Now I have the motor torn down completely and have all the parts of the piston removed. I know the rod and crankshaft is shot (heat discoloration and too much up and down play rod to crankshaft).
***so I’m wondering while I have the motor apart what should I check for? I know this motor died from heat as the oil in the head smelled like popcorn. So what should I check to make sure I fix the issue (overheating I assume) and not just the symptoms (blown up motor lol).
Here’s some pics
By cfauvel
ok help so according the service manual, Idle Air Mix Screw (aka Pilot screw) should be initially set to 2.5 turns out from fully seated.
If I do that the motor doesn't want to start or stay running...right now the pilot screw is probably somewhere near 5 turns out....I'll take the carb off tomorrow to count to know for sure.
mind you the carb got a new float seat,float needle and various other components in the kit.
To get the motor running I hard to turn the pilot screw out quite a bit, and turned the idle speed screw in quite a bit...I didn't hook up an inductive tach to know what it is idling at, but does sound about right.
What should the idle speed adjustment screw initially be set at (the one that has the black cable sheath with a knob you can twist easily)?
Is there a special tool to turn the idle/pilot mix screw whilst the carb is on the running motor? I am using a slotted screw driver bit (normally goes into a driver) by hand..makes it hard to turn the driver and hard to tell how many turns .
By KX420Guy
Hey guys, Im new here but I recently Picked up a '99 Foreman 400 that apparently just had a top end rebuild. It blows white smoke like crazy and ticks/knocks and seems to follow the rpm's. I haven't done to much trouble shooting yet, It starts and runs like a champ and has good compression. I was just wondering if anyone has any suggestions as to where to go.
Oh ya the top end rebuild the guy did was according to him he honed the cylinder and replaced the piston and rings, my fear is an ovaled cylinder?
