on a 2000 quad master is the stator location on the left side under the pull rope or on the belt side. if you are setting on the atv the pull rope is on your left side. thanks getting ready to change the stator
oxidized black got the pull rope off all the bolts out of the stator cover, unhooked the two water lines and removed the hoses,, pulled off the gear that the starter goes into about a 9/16 bolt head in the center. now I see three screws do they have to come out to get the cover off,, cover is loose. I dont want to break anything thanks for the help. Raybob
yes it helps a lot on the housing that covers the stator the last one with the green x to the left of c and bolt looks like a pin going strait up and down does it have to come out. thanks for all the help. Ray
I have removed all the bolts that hold the cover on,, removed the water pump,,, cover rocks back and forth but it seems like something in center is holding it on,, there are three Philips screws .is there is a snap ring on the shaft. I have given up dont want to break the cover 2000 quad master 500 4x4, thanks Ray
I am going to change the oil and also change the final gear oil since some leaked out where do you drain the final gear oil and fill final gear oil and fill it. Ray
oxid black got my quad master fixed it was the voltage regulator. running good front brakes sticking hope it will free up. also have to adjust the back brakes. I just wanted to thank oxi black for his help. Raybob
  • 5 years later...
  • 3 years later...
I put a stator cover gasket on it, and I cant get the case back on it was really hard to push on. Tried to screw every other screw in to make push in. And cracked my case what am I doing wrong
    • By buriedpast
    • By hurnyak
      What is the best way to remove the carb on a 2000 quadmaster 500? Does the gas tank need to come off first?
      any ideas how to correct
    • By middlebrookgt
    • By tds7
      Do any have any experience replacing 2001 Big Bear 400 Front Differential Input Shaft bearing and seal. Getting ready to buy one but the seal and bearing are bad. Any help would be appreciated.
