Similar Tagged Content
By Wali
I was riding my 400ex one day and when i shut it off to put it in the garage i tried to start it put again to drive it into the garge and it wouldnt start.I put a compression tester on it and its like 30 psi with out throttle and 0 psi WITH THROTTLE.
when i put my finger over the hole it fell likes its pulling my finger in more then its pushing it out
Has good spark.When i took it into the shop the said it had 1oz of oil in it and a tiny pit of metal shaving(TINY BIT LIKE 30 flakes)
When i try to pull start (push start/roll start) it made a not normal sound and wouldnt stay running.
If my bottom end is blow why would it still turn over fine,
Are my valves siezed or not working properly
or is my timing off causeing valves to not open in correct order with fire
PLEASE HELP all help is appreciated
By Hunter Aldridge
Some times I get spark some times not can ride then it just dies and wont get spark it has new cdi box and stator but I don't know if it has the pickup coil I'm at a loss
By William Sims
I have a 400 4by4 ,2005 green model,
wounding how many different CDI boxes will work on it
By jerry houston
Eiger 400 Suzuki runs fine Cook-Out joke face off the handlebars put it back on and will not start now will crank no no spark
By colin james
View File 2012-2014 Polaris Sportsman 400 HD Service Manual
This the factory service manual for the 2012- 2014 sportsman 400 hd service manual
Submitter colin james Submitted 02/08/2019 Category Polaris ATV
Similar Topics
By MakeMyBoysProud86
I have a 1988 Yamaha Yfm100 Champ that I'm trying to get running for my 3 boys to ride. So far I have replaced the cdi, ignition coil, spark plug, ignition switch, battery, carburetor and the stator. The starter engages but it won't turn over. I'm getting fuel into the carb bowl, I have spark and I believe it has compression. Any ideas what I can do next to get it to turn over and run? Thanks
By Chrism
Hi all, new to this forum so thanks in advance for the help.
I have recently brought a 2013 power steering fuel injected foreman 500.
It has a crack in the front casing and was running rough. I have since replaced the front engine casing and this has made no difference to the engine performance.
It starts and idles but bogs down and starts to die once throttle is applied.
It maybe be but it also sounds very load.
I have uploaded a video link of it.
By donerightautomotive84
Ok so 2000 sportsman new.caltric carb new fuel pump new jug and piston new cdi and coil finally get to start it and itll idep for 5 to 10 seconds and die what am i missing people any help id love ya forever lol
Sent from my LM-Q720 using Tapatalk
By mywifeknowseverythin
Great sayings by police officers
These 16 Police Comments were taken off actual police car videos around the country:
#16 "You know, stop lights don't come any redder than the one you just went through."
#15 "Relax, the handcuffs are tight because they're new. They'll stretch after you wear them a while."
# 14 "If you take your hands off the car, I'll make your birth certificate a worthless document."
#13 "If you run, you'll only go to jail tired."
#12 "Can you run faster than 1200 feet per second? Because that's the speed of the bullet that'll be chasing you."
#11 "You don't know how fast you were going? I guess that means I can write anything I want to on the ticket, huh?"
#10 "Yes, sir, you can talk to the shift supervisor, but I don't think it will help.
Oh, did I mention that I'm the shift supervisor?"
#9 "Warning?” You want a warning? O.K., I'm warning you not to do that again, or I'll give you another ticket."
#8 "The answer to this last question will determine whether you are drunk or not. Was Mickey Mouse a cat or a dog?"
#7 "Fair? You want me to be fair? Listen, fair is a place where you go to ride on rides, eat cotton candy and corn dogs and step in monkey crap."
#6 "Yeah, we have a quota. Two more tickets and my wife gets a toaster oven."
#5 "In God we trust, all others we run through NCIC."
#4 "How big were those 'Just two beers' you say you had?"
#3 "No sir, we don't have quotas anymore. We use d to, but now we're allowed to write as many tickets as we can."
#2 "I'm glad to hear that Chief (of Police) Hawker is a personal friend of yours. So you know someone who can post your bail."
AND THE WINNER IS...
#1 "You didn't think we give pretty women tickets? You're right, we don't. Sign here."
